Just Installed Vg For Dialogic
1st problem:
104824.09 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Too few parameters. Expected 1.] line=210
104824.11 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Variable objet ou variable bloc With non définie] line=250
it keeps repeating that forever and the line isn't in my script or config.xml neither configline.xml.
2nd problem:
my line does answer very quick now that it doesn't wait for callerID but, if I put more lenght on other lines, the callerID still doesn't come up neither in the call log.
3rd problem:
all the sound files play slow! they are normal if I play them with winamp no problem but when VG access then when needed, it converts my 11k 8bit mono .wav file to .vox file and my cute woman voice sounds like a male retart now!
I looked around alot and haven't found how to fix any of that so i'll send you my configline,config and script.
Thank you.
Anthony.
Sorry I haven't looked hard enough, about the speed problem I will record them at 8khz instead of 11khz.
Stop VG, then delete file OutDial.mdb in VG's \data\ subdirectory, then restart VG.
2.
So CallerID doe not show up even if you answer call after 2 Rings or more?
You can enable the automatic saving of the logs to files in \log\ directory as well.
